Running a Domain Controller on a VM
28 Sep 2008
Britain
Using Hyper V. Am I likely to come across any issues?
Basically we're upgrading the PDC to 2008R2 (currently 2003). I want to build a 2008R2 VM, dcpromo it, let it replicate, make it authorative / primary, etc then rebuild the real DC server with 2008R2, dcpromo it then make that the PDC again.
Is this the best way to do it?
The DC VM will be temporary but I don't want to run in to any issues :)
I've run DCs in VM permanently in a production environment without any issues. One thing that you will need to make sure of is that the PDC is properly configured to obtain the correct time from an external SNTP server, and that you disable the integration service for setting the VM to the host's time. If you fail to do this, you could end up with the system clocks becoming vastly out of sync across your domain, which is a Very Bad Thing indeed!
Indeed. On my DC I have set the key
Code:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Parameters\NtpServer
To use the value;
Code:
time.windows.com,0x1
Although you can use any time server you desire.
I would never make the domain controllers totally virtual in production, you could end up with a sort of chicken and egg situation if something made everything shut down where your hypervisors come up without being able to authenticate against the domain.
We have a few virtual DCs, most of which hold the global catalog etc. but we have a physical server that holds all the FSMO roles too.
This is actually the issue I'm facing now. A VM DC is running but I can't remote access the hyper v box to change its DNS to the new DC. A visit to site tomorrow methinks!
