Running a perl script
OSB
OSB
26 Nov 2003
UK
Hi all i'm in a spot of bother here, i'm trying to patch a program (nothing illegal) using some perl script. I'm actually on a mac atm so am trying to do it in terminal. Am i right in thinking the command i need to run is:
sudo sh -c "perl PATCH_SCRIPT < BACKUP > ORIGINAL"
Where the items in caps are the addresses of the items, eg:
PATCH_SCRIPT = /Users/OSB/Documents/patch.pl
BACKUP = /Users/OSB/Documents/theapplication
ORIGIONAL = /Applications/theapplication.app/Contents/MacOS/theapplication
The script is:
#!/usr/bin/perl
while($line=<STDIN>)
$line =~ s/\$GetListLen([^A-Za-z])/\$TEGListLen$1/g;
$line =~ s/\$ListLen([^A-Za-z])/\$SILtLen$1/g;
$line =~ s/\$MyNick([^A-Za-z])/\$NYMick$1/g;
$line =~ s/\$MaxedOut([^A-Za-z])/\$XAMedOut$1/g;
$line =~ s/\$Supports([^A-Za-z])/\$PUSports$1/g;
$line =~ s/\$FileLength([^A-Za-z])/\$LIFeLength$1/g;
$line =~ s/\$Get([^A-Za-z])/\$TEG$1/g;
$line =~ s/\$Send([^A-Za-z])/\$NESd$1/g;
$line =~ s/\$Canceled([^A-Za-z])/\$NACceled$1/g;
$line =~ s/\$Direction([^A-Za-z])/\$RIDection$1/g;
$line =~ s/\$GetZBlock([^A-Za-z])/\$TEGZBlock$1/g;
$line =~ s/\$UGetZBlock([^A-Za-z])/\$EGUtZBlock$1/g;
$line =~ s/\$UGetBlock([^A-Za-z])/\$EGUtBlock$1/g;
print $line;
Basically i don't know if its patched correctly and i don't know if this is therefore the reason the program won't run properly.
Thanks guys!
This isn't exactly Linux or Open source, but...
Is is not cd to the scrips location and then:
Code:
./patch.pl < BACKUP > ORIGINAL
No need to invoke perl yourself as the shebang is present.
