running BIN and CUE files
12 Feb 2006
Surrey
i've got some software that is on my computer but hasn't been installed yet and is a BIN file and also there is a CUE file although that is very small (1kb).
im wondering how i can open this file and install the software?
cani download some free software that will do this or will i have to put this file onto a CD and then it will work?
also...
If i copy all the files from multiple disc from a game, for instance MAFIA, that had 3 CD's afaik and say i copuy all the files from them cd's onto my computer, can i put all the 3 discs worth of files onto 1 DVD and it still work?
im qworried that it may not as when putting in CD 1 of mafia, after it installs everuything needed it then asks for CD 2, but obviously if its on a DVD with all the fiels on 1 would it still ask for CD 2 or would it just know that the files are on the DVD?
final question..
using the same example as above, the whoel 3 CD's for one game thing, say i broke CD 2 but made a back up of it, can i put CD 1 in, then when it asks for CD2 i just tell it where to find the files in my documents?
thanks all
If they are in the same folder burn the cue to a disk using software of your choice, this will tell the compt to burn the bin file. Else use Daemon Tools
