Personally I don't drain the tank because it's an old car and may have heavy contaminants (e.g. metal filings stuff) at the bottom of the tank, and draining it would increase the chance of those damaging the engine.
You've got a fuel filter which will stop these getting into the engine.
Running it almost empty will pull all the crap through out the bottom of the tank, the fuel filter should stop it getting through but then its blocking up the fuel filter. Fuel filters are designed to filter fuel particles and general crap out of fuel, they are not there so you can run it empty![]()
Myth! The amount of movement a tank sees there is no way that kind of accumulation would occur. Besides which, as I understand it, tanks might have the exit at the top but a plumbed internally to draw fuel from the bottom of the tank...?
So - here's a few conflicting thoughts on whether or not driving with an almost empty tank is bad, and why. What do the rest of you think on the matter?
