20 Sep 2007 at 07:33 #1 Maccy Maccy Commissario Joined 23 Nov 2004 Posts 43,302 Location Herts Apparently another application is needed for this - can someone point me in this direction?
20 Sep 2007 at 08:39 #2 Darryn Darryn Soldato Joined 18 Oct 2002 Posts 4,449 Location Colne.... Up Norf. Woooh... there are so many kinds of .exe files its a hard one... If its a self extracting zip/rar you can use StuffIt, if its a proper Windows application you may need to use Crossover/Parallels/Fusion. Can you be any more specific as to what the file is?
20 Sep 2007 at 11:38 #3 Hamish Hamish Soldato Joined 14 Apr 2003 Posts 4,950 Location Deepest Yorkshire Could also try Darwine
20 Sep 2007 at 15:28 #4 Maccy Maccy Commissario OP Joined 23 Nov 2004 Posts 43,302 Location Herts It's a small application, think it's an msdos application that opens in windows.
20 Sep 2007 at 18:37 #5 Deleted member 651465 Deleted member 651465 Maccy said: It's a small application, think it's an msdos application that opens in windows. Click to expand... It won't work in OS X natively as the OS doesn't use/like executable files. You will have to install Boot Camp , Parallels or VMWare Fusion to boot in to Windows.
20 Sep 2007 at 18:44 #6 Hamish Hamish Soldato Joined 14 Apr 2003 Posts 4,950 Location Deepest Yorkshire Maccy said: It's a small application, think it's an msdos application that opens in windows. Click to expand... if it's a dos program DOSBox could be a good bet.
