want to buy an external hdd to take away with me for a huge trip but am worried about the voltage change over there. My laptop works as the plug says 100-240v but I am unsure about an ext hdd.
The bump will do you no favours, especially after an hour. People do read these forums and help wherever possible. If someone doesnt know the answer they wont reply. All i can suggest is do the same as you did for your laptop. check the external hdd and check the voltage rating. It all depends on the hdd.
