Running fans off USB-SATA power converters
22 Mar 2017
UK
I want to run some 12V fans off USB. It's a pain to solder 5V-12V step up converters so I thought I could use a USB-SATA cable instead like this one:
Can I then use the cable which comes with the Noctua fan? controller https://www.overclockers.co.uk/noctua-na-fc1-fan-controller-fg-05l-nc.html
(The bottom one with SATA power to 4-pin fan)
I know SATA power has 12V pins which is what I assume this cable is connecting to the fan controller?
Then I can run any 12V fans off the fan controller all from 1 USB-A providing power? Will this work?
Easier, if possible, to use one of those braided extensions Molex to 3 or 4 fans. You can even rearrange the pins to 12V, 7V and 5V for constant speed.
I'm not sure if the USB would pass 12v.
I was hoping it must have a step up buck converter to run the 12V pins.
Can you link to what you mean? I don't know how any molex power that runs off USB or mains.
SSD's and 2.5" HDD's run off 5v only. That's why you can't use 3.5" HDD's and CD-ROMs from that adapter as they both need 12v which it cannot supply.
Are there any USB to SATA adapter that will run full HDDs and DVD drives then? And presumably as they work off 12V they would work? The ones with two USB plugs?
How about this?
https://aliexpi.com/FaVi
If the link doesn't work search for this on Aliexpress:
Angitu Speed 12V/5v Voltage Step-Up USB to Dual 3-Pin 4-Pin PC Fan Sleeved Power Adapter Cable With Switch - 60 cm
Oh thanks that's great. I found nothing on ebay/amazon so didn't bother to search Aliexpress.
In the end I used an old 12V AC adapter and a cable rather than going via USB-SATA but that will be much neater.
That's perfect, cheers :)
