Hello, Morning all.
I want to run mains power to my garage (without killing myself).
I want to be able to run a couple of stip lights off one switch and maybe a double socket for use with a welder/grinder.
In my conservatior', I have a 13amp spur I could run some cable from, to the garage. This is currently being used to run off to two lights and an external security light.
Would it be viable to use this fused spur, to run in to the garage, then plubm it into a fused switch unit, then on to the lights and plug sockets?
Would the 13 amp blow if everything was being used at the same time :S
Any kits anyone recommends using for this kind of DIY job?
Thanks!
Jon
Thanks!
Jon
