hey all,
I'm fairly new to this batch file writing lark so I'm after a bit of help.......
I have a good avi to dvd convertor that i use, i also have about 30 avi's file that need converting. I know that you can start a program from a batch file but how do you go about making changes to the now open program?????
i.e load in a avi, make a dir with the same name as the avi, put that name in the "output folder" box, set it to PAL and set the aspect ratio??????
any ideas?????
cheers
blastman
any ideas?????
cheers
blastman
cheers
