Running SuperPI on both cores at once
9 Nov 2002
Surrey, UK
I've just put in my new X2 4400 and am busy seeing how far it will go.
I've worked out how to run Prime 95 on both cores at once (though it does seem slower than on a single core - it churns away on Torture test but doesn't seem to make much progress despite no errors).
How do I set up SuperPI to do the same? I'm running mod 1.4 btw.
Phil
Copy the folder you have super pi in, open one from each folder, open control panel, right click the first super pi and set to core 0 (affinity), right click the second one and set to core 1.
Then run them :)
