I wanted to install Vista as a virtual machine, using whatever software was most appropriate. Now I foolishly assumed that Virtual PC 2007 would be the best option as its still beta, but when I try to install it (Im running XP Home at the moment) it says the OS isnt supported. Is this cos I'm using XP Home? Could anyone suggest if it is possible to run Vista as a VM - I just dont want to go to the hassle of sticking my old hard-drive in just to see how Vista runs.
Cheers for any advice folks
