- 1 Jul 2007
Looking for some help and advice.
I suffer from running water noise in my radiator and I can't seem to cure it. It happens when the heating comes on and can be loud enough to wake me, it's like a shower in my room!
I can bleed the thing when it makes the noise, bleed each radiator individually, bleed the one that usually collects the air. And repeat the procedure when it's not making a noise. Both times all I get is clean water out and makes no difference.
There doesn't seem to be any hot or cold patches on my radiator and according to my dad there is no fill tap for the system.
Anybody aware of anything else to try?
