If you set your HT multiplier correctly, can running with a high HTT in of itself cause stability issues?
I ask as I realised that if I lower my CPU multiplier to x8, increase the HTT to 337 and run on a memory divider of 133, I can run at 2.7GHz(which I'm near to proving is my max stable speed)but increase my memory speed from 192MHz to 225MHz.
Any advice would be welcome as I don't want to start another round of stability tests, only to be baulked by stability issues bought on by having a high HTT.
I don't know whether the CPU and brand of motherboard have an affect on this but I have an Opteron 144 and an EPoX EP-9NDA3I motherboard.
Cheers, dagwoood.
P.S. I realise if I set my HT multiplier to x3 and set the HTT to 337 I'd be running the Hypertransport slightly over spec, but I presume this wouldn't cause any problems.
Cheers, dagwoood.
