Running XP on a 64bit machine
30 Aug 2006
Running xp on a machine such as the OcUK Titan is obviously not ideal but is it only the memory that is limited or are there other parts of the machine that would not run as well with xp.
Running 64bit is a lot deeper then just memory advantage though it is the main advantage no doubt. I wrote a very long post on it on another forum a long time ago but i dont think finding it will really proove any more help to you anyway.
If you run xp instead of vista you wont really noticve the difference unless running apps that will benefit from 4gb of ram. Genearaly games do not with an except few.
