Runtime Error
9 Dec 2008
Hi
Not sure who I am to blame for this. Visual C, Kaspersky or Bad Company 2 but so far I have only had this problem twice, both times whilst playing Bad Company 2.
I'll be playing and then all of a sudden I will lose control to the game the window you can see below pops up
Bad Company 2 doesnt close down and nor does Kaspersky, I have to minimize and press ok on the pop up window first but then I can continue playing Bad Company 2 and Kaspersky doesnt seem to disappear anywhere either.
Thing is, Its just really annoying to know something isnt right with my PC annoys me too. Anyone have any idea what this means, whats causing it and how I can try to fix it?
Regards
I uninstalled Kaspersky and Microsoft Visual C++ (there were several of those visual c's in 'uninstall program' so I removed them all.
Then I reinstalled Kaspersky and the latest visual C++ via windows update
Still getting the same problem :/
http://support.microsoft.com/kb/126709
Sounds like you might need several visual C++ installed at once.
Never uninstall visual C++, I have about 10 different versions of visual c++ libraries installed on my pc.
Look on the bad company install dvd and you might find some visual c++ install extras, try reinstall them.
Other option is to find another virus scan software.
Gone and had to give up on this one, No one seems to know the answer for this, asked the same question on a few different forums, emailed kaspersky & the company I have a year free tech support for my pc with.. no one seems to know so Ive deleted kaspersky and just using microsoft security essentials now.
Remains a mystery either way
im touching wood that my pc is fine and that the only error i was receiving is because of kaspersky.
thanks all though
The only thing that sticks out as odd to me is the address of where you have Kaspersky installed.
Is the D:\ drive the same drive that you have windows installed on?
If it is then ignore me.
If it isn't then I would try installing Kaspersky on the windows drive and seeing if you still get the error.
Just a thought!
Hiya, no kaspersky was installed on D: and windows is installed on C:
I did try reinstalling kaspersky to the C: drive though but I still got the same error pop up, so Ive uninstalled it now
right click kaspersky > settings > exceptions > add BC2 at the top level and click ok > make sure the 'include subfolders' box is checked > apply
let me know how you get on, i can gurantee you is KAS that f'ing up.
Ive had to uninstall it, im using microsoft security essentials instead now. its a shame as i paid for kaspersky and this is free, but MSE makes me realise that kaspersky was slowing down my computer abit too so im thankful really.
I feel I tried everything, including what you suggested wouldnt know what else to do and I cant get rid of the error popping up
Thanks though, and everyone else
