Rust in bay res
Not the best pic, but here you go
What coolant were you using? the will probably be something in the manual for the res about only using a certain type of EK coolant. From a design POV that's pretty silly of them though, what are those? mild steel or chromed mild steel screws holding in a stainless steel plate? should have used a plexi plate.
