Rusty Mount
17 Sep 2007
Liverpool
Hi everyone,
Think this rust has gotten to the point where it will need replacing? I haven’t had the car long and it doesn't seem to be a problem. Should I remove the rust and paint it to stop it spreading?
Thanks
Thanks for the quick reply :) I though it was only surface rust but when it started flaking off in chunks I was a little bit worried
Where is the oil leak?? ;)
(You have only had the car a short time and it looks very much as if the engine bay has been jetwashed! That is why it is rusting! :D )
Get some Hydrate 80, paint it on and It will never rust again! (Especially if you spray afterwards with waxoyl)
I wouldn't worry about it, probably point a can of wd40/lithium grease at it if I had one in my hand though! That is a very clean engine bay though!
