nVidia's shaders are clocked much higher.
i know NVIDIA don't have there shaders clocked at core speed, surely AMD are shooting themselves in the foot by not adopting NVIDIAs system, surely less shaders is better?
also remember the ATI shaders are 5way
yeah isnt this the same thing as the last card that supposedly had more than nvidia but it was the way ati and nvidia counted them differently
The shader designs are completely different. One Nvidia shader can do one operation fast, whereas an ATi shader can do upto 5 operations depending on what it is doing, but does them slower, so if it can only do 1 or 2 operations then it comes off worst. But if ATi can boost the clocks it will give them an edge.
