- 24 Mar 2013
- C-137
Hi all
I have had this card in my second PC for a while, which I purchased from OCUK on 1st Sept. It's the Sapphire RX 470 "reference" style card:
https://www.overclockers.co.uk/sapp...s-graphics-card-with-backplate-gx-37g-sp.html
Now, the advertised clock speeds on this card are base: 932MHz, boost: Boost Clock: 1216MHz, which the card cannot sustain. The boost clock is never hit, and often the card will drop below even the base clock. This is in a Silverstone TJ08-e with the drive cage removed, the stock 180mm intake fan and a 120mm exhaust. Airflow is unrestricted and there is plenty of space around the card.
Am I right in saying that if the card can't hit it's advertised clocks, at stock/out of the box settings then it's faulty?
I can get the clocks to maintain if i do some mild overclocking in Afterburner, which is why I never really noticed it up until recently, as I had a small overclock on the card from day one, (+30 power, 1250 core, 1825 mem), but I want to put in into a smaller case for some living-room friendly gaming but it being a SFF case, it gets toasty, hence why I want to go back to stock.
There's two main problems for me with the way the clocks on this card go; it makes for poor frame times, and a "juddery" experience as the clocks constantly change, and it doesn't perform nearly as well as it does when it's maintaining its clocks. I have tried the card in another system, and get the exact same results.
Do I have a case for an RMA? Even If I do get a return and they let me swap the card for another, am I likely to experience the same issues?
In fact, being nearly 6 months ago, would I have to raise this with Sapphire themselves rather than OCUK?
Thanks for your time
