Right guys so after having a nightmare with amazon over a missing RX480 Devil, I've finally managed to get my hands on A gigabyte RX480 G1 8gb. now I know these aren't up there with the best custom 480s but I don't think there also as bad as there made out. I'm having a problem while using AMDS wattman overclocking tool, I've managed to settle on a overclock of 1380/2200 with temps around 70-75c using 1100mv at stage 7 and stock memory voltage. I've Tested this overclock using Valley/Heaven and 3dmark Firestrike and Hwinfo64. I don't experience any Artifacting or throttling issues at all and even the VRM sit at around 75-80c under full load. Now the problem is while doing some actual gaming, I can play for around 30 minutes then all of a sudden my games will crash with a error code like "error your video card may have been removed from your system or a video driver update is required" or "your system may not have enough resources to run at these settings". I've also encountered hard crashes while on the desktop out of nowhere with a pinkish coloured screen. none of this happens while running at stock speeds of 1290/2000 which leaves me to believe its a OC problem?
I just don't get why all my benchmarks are Rock solid stable.
