Hey folks so i got a new pre built pc from overclockers but had to return it for repair, had a faulty psu, the repair form says "psu was causing system to not work with a gpu, replaced with superflower 750w psu and tested on furmark and prime95 overnight" so i've just got it back, and everything's fine now except this one issue, at first i couldn't get a signal on any gpu so used integrated graphics, then after using DDU the pc is now picking up a dedicated gpu in device manager.
i plugged in an old R9 280 after the 480 and it works fine no problems, but when i plug in the RX 480 there's no signal and also no power to the keyboard and mouse when plugged in, my specs are b450m, 3400g cpu and a superflower 750w psu. The 480 works fine, lights up and fans spinning it's not an issue with the card. The msi 480 is 8 pin/6 and 2, but the psu sata cables in the pre built pc are all 6 pin and there's no 8 pin sata slot so is it simply the psu not enough power getting to the card. The psu has 4, 6 pin sata slots whereas the cpu and motherboard does have 8 pin slots. so it's obviously just a cable issue and not enough power?
