- 7 Sep 2012
- Lancashire, England
My new PowerColor RX 5700 Red Dragon arrived yesterday and I got round to installing it today. Installation was easy enough as usual (completely removed the previous drivers for my RX 580). This is where the simplicity ends.
I got about 5 minutes in to playing The Outer Worlds and my GPU temp hit 95C, the memory temp hit 90C and the GPU Hot Spot reached 110C... Not Good! Turns out the fans weren't spinning up at all. The fan sensor then disappeared completely from HWinfo and the fan reading in Wattman went up to 65535rpm (when they weren't even moving).
I've tried auto and manual fan speeds, different driver versions, double checked all connections and tried both the OC and silent BIOS via the switch on the card. It seems the fans pretty much come and go when they feel like it. Sometimes they work, sometimes they don't (sensor reading ends up greyed or completely missing in HWinfo when they stop responding).
I'm guessing it's RMA time for this card already? I'm pretty sure the fan sensor/control is faulty.... I was hoping it was a driver issue, but I don't think it is.
System specs:
AMD Ryzen 5 3600 (running stock)
Asrock X470 Taichi with the latest BIOS
16GB HyperX Predator DDR4 3333 cl16
512GB Sabrent Rocket M.2 NVME boot drive
2TB Hitachi/Toshiba HDD
750W Riotoro Enigma G2 PSU (basically a Seasonic Focus Gold unit)
Windows 10 and all drivers are up to date.
What do you guys think? I even used separate PCIE power cables from the PSU to the GPU instead of using a single cable with both 8-pin and 6-pin connectors. I know some people say using a single cable with both connectors is ok.
System specs:
