So, with either a HDMI or DP cable plugged into the GPU, z77 MPower throws up a B2 error and hangs indefinitely. I get zero response from the display.
Sorry if this is in the wrong place.
Spec:
CPU: Intel Core i5 2500k (was originally overclocked to 4.5GHz, but brought back down to 3.3GHz with BIOS flash - [more info below])
GPU: Sapphire AMD RX480 Nitro+ 8 GB OC
RAM: 2x 4GB Samsung Green DDR3
PSU: EVGA SuperNova G2 550 W
MOBO: MSI z77 MPower
SSD: Samsung 850 EVO 250 GB
OS: Windows 10 Pro 64 bit
Apologies in advance if a similar thread exists. I’ve spent hours and hours on this now and don’t have any ideas left.
What I’ve tried/things I know:
I am seriously stuck on this. Short of paying out for a new mobo/CPU, I really don’t know what else to do. What am I missing?
Please, please help. I don't even know what's real anymore...
Spec:
- BIOS updated to latest version using MSI Live UPDATE 6 (more than once)
- Clean windows install (more than once)
- Most recent chipset drivers installed
- I get GPU LEDs but no fans
- Seated and reseated the GPU in all three PCI slots
- Installed the GPU in a friend's machine (works fine). I also Installed a friend's fully functional GPU into my machine, same B2 error, so I’ve pretty much ruled the RX 480 as the cause.
- ‘PEG' enabled as primary display output in BIOS
- Mobo’s on board display adapter works perfectly
- Have tried disabling on-board display adapter in case that was interfering — still no joy
- CMOS has been reset several times
- When using the on-board adapter, the neither the BIOS nor Windows acknowledge the card’s presence
