- 25 Jun 2005
Less a specific tech problem more advice.
Running an rx590 8gb which is lovely but noisy at full chat. What I'm seeing from the Radeon software is zero rpm until it hits temp then it spools up to ~1400rpm, it then cools down enough to drop to zero rpm. There's no gradual ramping, just binary on/off.
It never sits at ~500rpm which would be quiet and for easy unstressed use would cool enough. I've tried manual fan curve but the minimum I can set is 1300rpm.
Is there anything else I should try just to keep a stable temp when idling?
Computer Type: Desktop Overclockers' build
GPU: PowerColor Radeon RX 590 Red Dragon 8192MB
CPU: 3700x
Motherboard: MSI B450 TOMAHAWK MAX
RAM: Corsair Vengeance LPX 32GB (2x16GB)
PSU: Bitfenix Whisper M Series 550W
Case: Phanteks Eclipse P400 2x120mm intake fans
Operating System & Version: Windows 10
GPU Drivers: 20.9.1
Chipset Drivers: Provide the version of drivers currently installed.
Background Applications: Anything, even idling along
Gif here showing fan speeds
CPU: 3700x
GPU Drivers: 20.9.1
