Rx590 problems
7 Jun 2019
So I bought a new tower recently and wanted to swap over my rx590 to it. I installed it after swapping over the psu from old tower because new tower didn't have enough pcie cables and for some reason this pc wont recognise my gpu. When I boot the pc it will either spin the fans for a moment then they stop or the fans will spin at a very high speed constantly until I force shut down the pc. The pc never boots at all when doing this either, I will always get no signal. I also tried downloading all new amd drivers before installing the gpu and that did not work. Without the gpu installed the pc runs perfectly fine. The very first time I booted after installing gpu I think I got a message on screen saying new cpu installed, not sure though. Also you doesn't work now when I put it back in old PC either
ASUS A320M-K motherboard
Radeon Rx590 gfx card
Coolermaster 500W psu
