Hi people
was driving to work this cold sucky morning and i noticed a light on my Rx8 display, and thought hey this isnt usually on when the engine is running, did a little research in my guidebook and it says its the engine warning light
, possible engine problems, i rang my local mazda dealership and they said first off check the oil and coolant level, so off i go to check...and the coolant level is ok but yet its very warm under the bonnett, the oil is very low, there sending a technition out at around 2:30-3pm this aft.....i only had the car in there garage last week for a clutch and steering problem and now this
anyone else had this problem i know the oil needs topping up every 2 fill ups, ALSO...when i was on the phone to the recovery they said have i recieved the free RX8 starter motor upgrade, ive been in there garage twice in the past 4 months and not once have i been offered this
