Ryanair, grrrrrr!
22 Oct 2005
Moving...
I'm trying to book some flights on Ryaniar because there looks like some good deals on, but I cant for the life of me find out how you book it. Here's the link to the page:
http://www.ryanair.com/site/EN/cheapflights.php?dest=NTE&base=STN
I'm looking at going to Rome "from £12" but I cant see where you can book this. I've searched through the normal search bar on the left for loads of dates with no success, i've found a couple of flights for £0.02 but after adding the taxes/charges its nearer £50.
Any ideas?
Following your link the cheapest I've found is £12ish each way.
AS an example, this would be flying out on 5th March and returning on the 6th. There's probably other combinations that give this result too though.
edit: you could go out on 6th and return on the 12th for £23.54 which is less than £12 each way.
There's a red button on the left under where you select airports and dates - it's titled, "Book Cheap Flights".
£50 sounds about right for a return, the £12 refers to one way without taxes.
what he said
book here
also remember there are sooooo many exclusions
Booking Period: Tue 19th Feb 08 - Thu 21st Feb 08
Travel Period: Sat 01st Mar 08 - Wed 30th Apr 08
Applicable Days: Mon - Thurs & Sat (subject to availability)
Flight must be purchased: 14 Days in advance
Blackout Period: 19th Mar '08 - 26th Mar '08 all routes
Notes on this fare: All Holidays, School Breaks and Major Sporting Events are excluded from this offer
Ok thanks guys. I have experimented with a few different locations and it's the same story, only one set of flight combinations works out to be around the stated mark.
On a side note, does anyone know of a flight comparison website that is actually good? I mean one that looks at deals as well and doesn't give £1000 flights to France. I've tried lots but it's often the case that I use the comparison site, then look on the actual company's site and find it cheaper.
Thanks again.
I got two flights to Berlin for 2p each way!
Shame taxes, check-in, luggage allowance and what not put it up to £85 for the two return flights. Still bloody cheap though!
Yea, nantes going on the 10th and returning on the 13th is 2p each way, even with taxes it's only 25 quid.
If you lived near the airport you could commute :)
Thanks again.
http://www.skyscanner.net/ << i've used this one before, you have to book through the website of the airline though.
