Ryzen 1200 and strix rtx 570 oc help
5 Mar 2019
Hey I need your help
I am benchmarking my cpu on cinebench r20 and got a score of 1241 with it at 3.8 ghz 1.35v and was just wondering if that is a good score I don’t know how to compare it to anything ahahah any help would be greatly appreciated
Also I am trying to benchmark my gpu which is a Asus strix Radeon rx 570 and I want to over clock it do you know what settings I should have it at ?? Considering I have that cpu I don’t want to unbalance anything
Thanks !!
My gpu sits at around 40C when playing games I don’t know it’s weird ...... I just oc it to 1400 at 1150v and it’s runnign fine
As for the cpu I just looked at the stats and I can’t find a ryzen 3 1200 on the list to compare it to or will I compare it to a r5 at the same frequency ?
Can you tell me if 1241 is a good score on cinebench though I can’t tell?
Thanks man appreciate it
My i5 6600 at 4ghz dose 1137 and plays all game I do fine.
With a strix you it will have a low core temp as the vrm overheat and throttle. My old one would do all games I play at 55c but vrm was 89c.
I changed it for msi model
