ryzen 1200 temps
Permabanned
6 Feb 2010
Barnsley
i have a ryzen 1200 in my media centre with the cooler from my 1600x fitted, the CPU is at stock speeds and a well vented case.
my idle temps ar 45c dose this sound right?
It doesn’t seem dangerously high, I think my 1700 on the stock cooler was only slightly lower. Is the cooler making full contact and how big is the case? If it’s a small case for a htpc airflow could affecting it?
case is a nzxt s340, but even with the side panel off its still in the mid 40's.
when my 1600x was a stock speeds with its own cooler it was low 41/42, i also know of people using the 1600x coolers on lower spec cpu's for overclocking.
i just thought a cooler for a 6c12t CPU would deal with a 4c CPU no problem. i will try resetting the cooler latter with better paste.
Fair enough, I wouldn’t be worried about those temps though. Put it under stress for an hour or two, see how hot it gets.
