Ryzen 1600 Bundle issue
1 Feb 2017
Hi 8Pack I brought the 1600 bundle and have it up and running. Loaded up your OC profile and PC loaded fine. Checked the settings and they all have loaded. The issue is that when I switch the PC on from cold it comes on for maybe 2-3 secs then turns off, then back on without me doing anything and continues into windows as normal.
I know Ryzen is strange with RAM so changed it back to auto which has sorted the issue and its loads up on 1st boot but its sitting at 2132.
Yeah flashed to bios posted. Got no idea what it is but its been fine the last couple of days so fingers crossed it stopped.
Did you leave it on at the wall when it doesn't do this? I had a PC that did the same and it just needed a new battery. Seems unlikely on a new motherboard though.
