There all very good i would pick the one what suits your system if you have a window case. You may have to order an AM4 bracket from the manufacturer for the coolers.
Not yet. Waiting till i get some better case fans for airflow.Have you overclocked it? If it's only 44c now it's got loads of headroom.
you really should. 44c is freezing and lots of people are able to oc on the stock cooler just fine.Not yet. Waiting till i get some better case fans for airflow.
H440 is not known for its amazing airflow.
Payday is sat for going to change my intake fans for noctua nf-ff12's x3 and the exhaust on back.you really should. 44c is freezing and lots of people are able to oc on the stock cooler just fine.
gpu hits 80c atm.Honestly I wouldn't bother. You may well find you don't need them.
Fair enough lol. I was under the impression you wanted the cpu running even coolergpu hits 80c atm.
Howd you unlock the core on the 1500x?
I am guessing asrock will get it done first as there skylake none k oc things works very well.
