I don't know why more motherboards don't allow the Asus Flashback style of updating BIOS, it would solve all these headaches we've had for decades.
I know what you are saying about it costing more for the feature but after all this time you'd have thought something like Flashback would become fairly mainstream on any board costing £80+ that could be used with newer CPU's.i think few other vendors do... problem is... flashship models were to be fair, people do constantly update their bios . im guessing board design costs a bit to be able to set up bios update without ram or CPU
Yeah socketed BIOS chips would be great, you can buy them on ebay now however you need to be good with a soldering ironfew, or bios chips designed to slot into a socket. might make life easier placed like OCUK offering bios chips flashed and you just rip out the old and slot the new without soldering
it should do but as always the beancounters probably block it stating it will trash high end board sales if these features were spread around.I know what you are saying about it costing more for the feature but after all this time you'd have thought something like Flashback would become fairly mainstream on any board costing £80+ that could be used with newer CPU's.
I remember about 5 or so years back JJ in an asus vid when asked by paul said asus would do things like onboard power and reset buttons across their entire product portfolio, instead things went the other way, like now the q connector is high end boards only, capacitors are lower spec than 5 years ago, and some bios features got caught on mainstream asus boards as well.
I put a 2700X in my B350 Strix which previously had a 1700 that is now in another system.
With a CM 212 Evo it boosts between 4-4.05GHz on all cores (27C ambient) with stock settings.
Still could not boot past 2933MHz with my Corsair (Hynix) RAM. The 2700X didn't improve memory stability on my B350 Strix board.
Have since swapped the B350 Strix for a X470 Crosshair and the RAM now runs at 3200MHz with XMP.
I was pretty happy with the Strix overall though, didn't seem to have any problems with the 2700X. Would have kept it if it wasn't destined for another system![]()
