Ryzen 2600x bundle issue
Well I've swapped them about but same issue...Is there a right and wrong way with a Ryzen build?
try one stick in second slot ( empty, populated, empty , empty ) - and boot up and see, try a benchmark like Cinebench .
then take out the stick and use the other one and do the same.
this will see if one stick is faulty
did you go for 3000 or 3200 hz ram ?
sounds like a first reading, may be a faulty ram kit - if it is, under 14 day purchase period, ocuk should swap it out :)
with both sticks in - normally goes ; empty-populated-empty-populated
That's the first setup i tried :). Gave up at the weekend in frustration : / i will test again tonight thanks for the feed back much appreciated.
Well folks I ran a mem test on each stick. Then updated the chipset drivers and installed both sticks once again as before empty populated empty populated and all seems to be going ok.
Was able to perform multiple tasks and even get PUBG running...so go figure lol.
Thanks for your feedback.
