- 8 Sep 2019
- Lincoln
Hello all,
Recently purchased PC appears to have high temperature CPU and I would really appreciate some advice.
System spec as follows:
Gigabyte Aorus B450 Elite; Ryzen 5 2600X (standard cooler); Sapphire Vega 56 Pulse; Kolink Stronghold Case (2 x 120mm fans); 2 x 8Gb Vengeance 3000.
I only really noticed the high temperatures by accident after reading some threads on here, and trialling HWMonitor, CoreTemp and latterly RyzenMaster software.
I bought this PC primarily to run Elite Dangerous in VR and purchased an Oculus Rift S after buying the PC, although I also liked Beat Sabre as another "reason" to go VR.
I noticed that running Elite in VR on the default graphics settings my CPU temps hit highs of 88 to 89 deg C after 30 min of play.
So that got me thinking about normal temps. As I type, RyzenMaster shows up to 56 deg C. HWMonitor mirrors the RyzenMaster CPU temps accurately, and just now shows max of 65, just from downloading and installing a couple of Gigabyte Apps...
The other morning I played Shadow of War for 30 minutes and temps reportedly hit a max of 96! There were no system crashes or glitches or weird behaviour. It just looks as though it gets hot. So I installed a 140mm inlet fan to make sure airflow through the case was sufficient. Vega graphics temps are reporting always slightly lower than the Ryzen 5, which I find odd? The third case fan doesn't seem to make much difference in temps, even though airflow seems better (tested with a trace of smole from an incense stick!)
I've only just managed to find the Ryzen Balanced power plan,so I've now switched to that.
I've also ordered a DeepCool L120 as recommended in another thread, to see if that works? I didn't know if the thermal coupling between the processor and the standard cooler may be insufficient, but can't really unplug it to find out, although it appears to be seated firmly...
However, I have another odd problem that I think might be related. In Elite Dangerous, I "should" be able to run far better graphics settings. I have a friend with a Ryzen 1600 system and the exact same graphics card as mine, and he's able to run an original Rift VR with supersampling at 2.0 (mine at 1.0), more powerful antialiasing, and HMD quality at 2.0 (mine at 1.0). When I load his settings, my rig can't cope, drops frames even just looking at the information board while docked at a space station and generally stutters really bad without even launching the ship. Needless to say, CPU temps hit high 80's.
In Ryzen Master, it shows that I'm constanly running 95% of peak current (125A) on the stock power plan...
I will install the DeepCool cooler at the weekend, but any advice or tips beforehand on what else to look at would be appreciated.
Yours Aye
Mark H
Yours Aye
Mark H
