Is this a Straight Power 500w? If so which version is it? Depending on the version it will have either 456w or 480w across quad 12v rails. The older 456w version isn't particularly good but the newer 480w version is ok although personally I would want a bit more spare headroom especially if you overclock anything. As your psu is a multi 12v rail unit make sure you power the gpu with two seperate pci-e cables.
