- 22 Sep 2016
Hi there,
I recently swapped a 2700x for a 3700x into the same mobo and with the same cooling...and I was surprised to see that the 3700x ran way hotter than the 2700x...even with the huge Noctua NH-D15 with 2 fans. Like at idle, it would sit around 50-60 degrees and under load would be around 70-75.
Obviously higher temps = more fan noise, and regardless of whether it's safe for the chip to run hotter, it's a pain in the ass hearing the fans whirring up and down all the time when i'm just browsing the interwebs - and even with days of fan curve messing...i've not found anything to tame the chip.
Until...I found a video on Youtube of some dude that just used Ryzen Master to set a all-core frequency of 4.3Ghz and a V-core of 1.25 and it lowered his idle and load temps. I'm not really someone who has the patients to deep dive into eeking every last bit of performance out of it...and this solution seemed like a really nice set it and forget it option (providing it was stable).
So I have just spent a quick hour doing some preliminary tests, starting at 4.1 and working up to 4.3Ghz @ 1.25v, using Cinebench as a quick "does it it immediately crash" test - and I've so far run 3 successful tests on each set of settings, and my score went up by between 400-500 points and thermals are a nice 40ish on idle and 65 under load.
It all looks sweet...but I can't help but have that feeling of it being too good to be true (or too easy to be true). Just wondering if anyone has any thoughts on whether this is legit? I have looked through reddit and everyone is doing different things and have differing opinions...could do with some reassurance from non-reddit people
Thanks!
Thanks!
