- 29 Aug 2010
- Cornwall
Hi,
I've currently got a Ryzen 5 1400 in a SFF gaming rig (Silverstone ML08-H case).
I'm struggling to find a decent cooler for this CPU that will fit in the case. The Wraith Stealth cooler that comes with the CPU does fit, but does a ****-poor job. The Wraith Spire won't fit. Last time I looked AM4 made finding a good low profile cooler challenging.
So I'm tempted to switch to an i5 8400. A little easier to find coolers, but I'm not sure if they're any good at cooling. Does anyone know how tall the stock cooler is?
For a gaming rig is it worth switching from a 1400 to a 8400 (given that the cooler option probably won't allow for any real overclocking)?
What about the 9400F, is that a better shout than the 8400? It's clocked 100MHz faster, but lacks iGPU. I'm unlikely to use the iGPU, but if it's there...
So which is best for gaming? Which runs coolest? Any decent, inexpensive low profile coolers I can use on either?
Thanks.
Thanks.
