hi.
What cooling gonna be the best for Ryzen 5 2600? I gonna overclock. Budget about 70 euro. Case is corsair carbide 500r
Thanks
Thought i'd ask in this thread hopefully without hi-jacking (also might add something for you Zed) but can anyone tell me how quiet the stock cooler that comes with the 2600 is? It's the wraith stealth far as I'm aware. I have a nh-u12s I could get the AM4 bracket for £12ish if it's worth doing that over the wraith would anyone know?
Noise and performance comparisons:
hi.
Thanks
Good cooler. I'm sure you will like it.I went for scythe mugen 5. 50 euro and noctua D15S performance
You should be able to get an AM4 bracket free of charge from Noctua.
https://noctua.at/en/nm-am4-mounting-kit
**Nevermind, just noticed you are aware of it**
