- 18 Oct 2002
I've just yesterday built a Ryzen 5 2600 based system and my experience is pretty much similar to you.
My rig is in a Micro ATX mini tower case with one low RPM 120mm exhaust fan. Also got a Zotoc Mini GTX 1060 3GB (with a smaller heatsink and fan combo compared to other 1060 3GB's).
My CPU hit 79C under Prime.
As muon said earlier, the Wraith Stealth is to blame.
If I touch the heatsink with my finger during a Prime run, it is absolutely roasting to the touch. This is telling me that:
1. Heatsink and CPU contact is fine
2. Heatsink is doing its job of transferring heat away from the CPU
Unfortunately, the heatsink is so small that there is nowhere else for this heat to go and there is only so much air flow the fan can push.
The Wraith Spire should have been bundled with this CPU imo as there is a noticeable difference in size and potential CPU cooling performance.
Prime is absolute worst case scenario so doubt I'll see those temperatures with normal usage, so I'll leave the setup as is for now. Long term, I'll probably look to replace the Wraith Stealth with a Deepcool Gammaxx 400 or Raijintek Thermis for around £25; either would be infinitely better than the Stealth. Shame, as I probably would have been satisfied with the Spire.
