Hi
Looking to do a cheap but snappy build for general browsing, excel, etc. Nothing too heavy. No gaming or movies. Budget about 500 to include case and PSU but not monitors and peripherals.
Can I use a 3400G base with a B450 board that has integrated graphics? [Edit - title fail, meant 3400G not 3500G!]
Are there any boards that work with the 3xxx series out of the box without needing BIOS flashing etc. MATX would be great but if it has to be full size that isn't a deal breaker
I wondered about this board for example.
https://www.overclockers.co.uk/gigabyte-b450-aorus-m-socket-am4-ddr4-matx-motherboard-mb-573-gi.html
And maybe this RAM?
https://www.overclockers.co.uk/cruc...gb-kit-2-x-8gb-ddr4-3200-udimm-my-20b-cr.html
Plan would be to try and run the memory at 3200mhz which I know from old ryzen build makes a nice difference, but to use STOCK HSF and no CPU over clocking.
Many thanks
And maybe this RAM?
Many thanks
