- 9 Nov 2020
Hello.
I 've just completed a build with the following components:
cpu: Ryzen 3600 - no wrath cooler
mobo: Asus prime x370-pro
gpu: 5700XT sapphire nitro+
ram: g.skill flare x 16gb 3200 14cas
psu: super flower 450w platinum king from my old pc
So what happens. I build it and everything runs smoothly until i login to a game. After 5 minutes the pc shuts down. It tries to restart by itself 2-3 times but it cant and then i shut it from the button. I try to turn it on but nothing happens. Only after lets say 5 minutes i am able to turn it on again.
Then i run prime95 test everything seems ok while running i monitor the temps aswell from hk monitor and the exact time i press stop i get that reboot. I tried without xmp enabled and the same thing happened.
Some times i dont get system reboot but only the screen is freezing to what it was showing and i have to turn it off manually. but to remind i have to wait some minutes before it is able to boot again... :/
I also tested with my old ram crucial basilisk 3200 8 gb which doesnt seem to fix the issue.
I know the psu is only 450 but its a tier platinum shouldnt it be able to manage a stress test that does not include the gpu?
Any ideas??
Thanks in advance!
Any ideas??
Thanks in advance!
