Hi,
Quick question, I have already ordered but there is still time to change it.
Everything I have read says that the 3600X is not worth it over the 3600. There is little evidence that the 3600X have been specifically bin-selected and that the 3600 is likely to clock to 3600X stock speeds and as much beyond. And that although the 3600X comes with a better cooler, you would be better off spending the difference on an after market cooler.
In summery the extra £30-£40 for the 3600X is not worth it, better spending the money on a cooler.
BUT, what if the difference between the two is only £13.
Would you go for the 3600X then?
Interested to hear your views?
Cheers,
Nigel
Cheers,
Nigel
