Ryzen 5 3600x question
19 Mar 2011
Looking to buy this cpu, will the dark rock 4 cooler be sufficient for this cpu i would also like to fit both onto an
B450 TOMAHAWK MAX (SOCKET AM4) DDR4 ATX MOTHERBOARD and get it all into a Phanteks ECLIPSE P400 AIR MIDI TOWER DRGB CASE - BLACK
will there be enough clearance?
the dark rockpro 4 handles my 3900x like a champion so it will be enough for a 3600
as for clkearamnnd the case only Max CPU cooler height: 160 mm the drp4 is 162.8mm high so i dont think it will fit
