i have picked all the components for a Ryzen build. I am stuck between Ryzen 2600 or the 2600x.
I’ll not be overclocking and using the pc for gaming so is the 2600x still worth the extra £30 compared to the lower priced 2600
Yes I have thought about the so no it’s not a joke. Would help if you just answered the question
I need to build a system for my nephew and at £120 and possibly lower in the next few weeks the 2600 is very tempting, the 3600 is £60-70 more atm
Buy what you can afford, you'll be just as happy with any of those cpu's
The Ryzen 5 2600 is now starting to go as low as £120 if you shop around(and I have seen dip even lower with discount codes),which is a £70 difference from a Ryzen 5 3600. So if the OP is also needing to buy a new GPU for their new rig,then £70 there would be the difference between an RX570 4GB and a RX590 8GB or GTX1660 6GB.
The issue is i am sure the motherboard I want which is a b450 gaming pro carbon AC would have to have a bios update to use the 3600 ( which I did think about getting) I don’t have the resources or knowledge to do a bios update.
Also I do have to buy a gpu and gone with a sapphire rx590 nitrous. But getting a 3600 and that gpu are in my budget.
As I said and I should have made it clearer is I am sure the motherboard would need a bios update
Ok the info has made things more clear. I didn’t think doing a bios update was as easy as it sounds.
So I’ll be getting the 3600 which is what I wanted in the first place.
