- 6 Jan 2013
- Rollergirl
Does anyone know when/if a refresh is due for X570? I want to upgrade my 3700x but don't want to go 5800x if there's a refresh due?
X570 boards with properly designed chipset cooler have been capable to passive cooling from the start in properly cooled cases.Boards based on the X570S (the "S" stands for Silent apparently) are due out soon-ish (I think Q3 was hinted by Asus).
There will be a Zen 3 refresh tho its more than a slight bump in clocks and a rebranding, they are gluing an extra 64MB cache on top of each die, 3D Stacking. According to AMD that will yield an extra 15% average gaming performance.
Not landing until early next year tho. Also on existing AM4.
Yes. Have to wonder which SKUs though? Probably only 5800XT, 5900XT and 5950XT.The only thing that's been said is the prototype 5900X with stacked cache shown at Computex will go into production end of this year. The demo showed a 12% uplift in gaming performance. So a refreshed Ryzen 5000 series around March next year?
Depends on yields, since chiplets are chiplets are chiplets, and if you're stacking some cache on a 6 core chiplet then there's no reason not to do a 5600X. I think it greatly depends on how Alder Lake performs. Even if the big little design works well with Windows 11 (and rumours suggest it does) it's still not taking productivity crown back from the 12 and 16 core Ryzens. So, it's actually the 5600X and 5800X that would see more of a benefit in the marketplace.Yes. Have to wonder which SKUs though? Probably only 5800XT, 5900XT and 5950XT.
The chiplets of course will be more expensive because of the extra work, but everything has been designed to fit in exactly the same dimensions as Vermeer (hence AM4 compatibility), so I doubt the packaging cost will change. We'll see.What we don't know if how much does the extra cache die and more importantly the packaging cost?
If you're referring to the overall assembly process, that's done in Singapore and Malaysia, not at TSMC. They just make the chiplets. But that does mean Singaporean capacity is in question if the X models continue to be made alongside the XT models.Will they be capacity constraints with possibly only one TSMC packaging line able to do the work?
Apparently this isn't going to be an issue. TSMC's stacking technology is quite simple in comparison to Intel's, is already very mature and can reliably stack up to 12 layers. It's supposedly trivial to just stack 1 layer of "stuff" so won't affect yields.And for that matter, what is the affect on yields? In that could it be that a perfectly good chiplet able to be binned for 5950X or EPYC could be broken during the 3D stacking step?
Interesting. I think I could wait for that as the 3700x copes fine @ 4k/120Hz for now.
