I've been running my Intel i5 4670K at 4ghz OC on a Gigabyte Z87X-OC for somewhere like 6 years now, and it just doesn't cut it anymore. I've sinced upgraded my graphics to a 2070 Super and that made a big difference but there's a lot of bottlenecking going on.
Cyberpunk was the clincher, but I've also started work on intensive photogrammetry, and play VR too. So I'm finally biting the bullet and upgrading to get everything smooth again. Looking to replace my motherboard, cpu and ram.
I've firmly settled on the idea of a Ryzen 5600X. It just does everything I need at a very competetive price. The question is what to pair with it at a budget ideally under £650.
RAM seemed fairly easy choice, 3600mhz and 16gb with the best CAS timings possible. So I've gone with:
Team Group 8Pack RIPPED Edition 16GB (2x8GB) DDR4 PC4-28800C14 3600MHz
Photogrammetry does benefit from more ram, but games do not particularly. So I figured I'd save some money here and just stick with 16gb.
Motherboard I'm least decisive on. All it needs is the ability to do basic overclocks, and a bunch of USB ports. I'm leaning towards one of these two:
Asus Prime X570-P (AMD AM4) DDR4 X570 Chipset ATX Motherboard
MSI MAG B550 Tomahawk (AMD AM4) B550 ATX Motherboard
Both at £170. What should I go for? Or any other suggestions?
Lastly, I'm not going to bother upgrading the CPU cooler straight away. Going to use the stock one until next paycheck!
Sorry for big post. Hope you guys can help. Ta
