I was one of the lucky few to be able to get hold of a Ryzen 5900X on release day.
I installed the processor into my motherboard. Did a clean Windows 10 Pro installation including the latest chipset drivers from AMD.com and ran a couple of tests.
When I run Cinebench R20, within a few seconds, the CPU goes from 35 degrees to 87 degrees as reported by Ryzen Master. It never goes past 4.3Ghz.
Single thread score of only 612 but multi thread score is about right compared to the published reviews.
Has anyone else got the Ryzen 5900X on this motherboard but getting better single thread performance in Cinebench R20? I seem to be off by 20 - 25 points.
Are you getting better boost than me?
Trying to figure out if it is the motherboard BIOS immaturity or processor silicon lottery.
Also, on a side note, the Ryzen power plan option does not appear, just the default windows options:
Specs:
Ryzen 5900X
Asus X570 Prime-P (2812 Beta Bios) DOCP enabled
Corsair Vengeance LPX 64 Gb 3600 Memory (On QVL list for board)
Dark Rock Pro 4 cooler (Kept Ryzen 3900X below 80 degrees in same scenario)
Windows Spec:
Edition Windows 10 Pro
Version 20H2
Installed on 06/11/2020
OS build 19042.610
Experience Windows Feature Experience Pack 120.2212.31.0
Specs:
Ryzen 5900X
Windows Spec:
Version 20H2
OS build 19042.610
