- 19 Jan 2017
Hi
I have just built a machine including the following:
ASUS ROG STRIX B550-F GAMING Motherboard
AMD RYZEN 7 5800X
ALPENFOHN BROCKEN 3 CPU COOLER
CORSAIR VENGENCE LPX 3600Mhz RAM
When running the MSI Kombustor CPU burner, it is running in the red at 90+ degrees. If I run the same program on my i5 machine it runs at around 67 degrees.
I know that the Ryzens run a little hotter than the intel chips, but is that much of a difference usual, and should it be that high ?
Thanks
AMD RYZEN 7 5800X
Thanks
