Ryzen 7600 Base speed OC
8 May 2025
Slovenia
Hello, i have one question about base and boost speed.
I tested 7600X and non X in CS2, and X version have about 80 more fps.. its not about boost OC, because i put them on same levels with PBO. The base clock on X is about 1ghz faster...
I wanna know is there a way to get uplift in base clock while staying with same boost speed. I tried to uplift base clock but all the time i was only getting fixed OC all core, 5000mhz acros all cores, but when i turn it back to auto i get 5500mhz reading acros cores in OCCT with boost... Soo is there way to KEEEP a BOOST 5.5, while OCing base clock to match the X model.
The base clock is a red herring, they're pretty much meaningless.
What FPS level are we talking about? 500 and 580? or 80 and 160?
I am just intersted in finding a way, if there is a way to OCing base clock while Boost OC remaining the same. I only managed to find all core OC or factory baseclock + PBO boost OC.
