- 21 Oct 2006
Should i get a 7900x £350 or wait to see if 7900 come lower. Will be air cooling Phantom Spirit 120 evo?
I got a 7900 for £357. So went for that with power saving over the 7900xyou can always run on eco mode with very little performance lose.
I do video editing sometimes so thought the 7900 gave best in both worlds. Though i can't wait to get gameing COD again.For 7000 series you get what is cheaper. For some odd reason, sometimes the X version is cheaper. You can PC the non-X and get X performance or use Eco mode and run the X version at bon-X heat and performance. The non-X gives you a cooler, that most people won’t use, but is nice to have around if the AIO, which most people use nowadays, fails.
I was tempered by the 7900 too, but decided to get the 7800x3D as the only intensive thing I do is gaming every now and then, but I guess the 7900 still a great CPU for gaming, plus the 12 cores for productivity. Hard choice for those who actually benefit from 12 cores.
Previously using the 7600 non-X and let the motherboard OC it, safely monitored (just in case), and even on Cinebench, all core load, Thermalright cooler or 360 AIO, with the CPU pulling mid 90s W, and a constant 5.15GHz all cores, temperatures never above low 80s Celsius.
All parts bought, just waiting for my Mum to build it for me.Sounds like you have an itch only an upgrade can fix..
Your mum builds PCs? Kudos to her. Learn from her, its not difficult, and you may enjoy it.All parts bought, just waiting for my Mum to build it for me.
at which point your probably better off with the 7800x3d.you can always run on eco mode with very little performance lose.
I'm paralysed from the neck down, some arm movement. I tell Mum what to do and she does it. Shes 70. She quite enjoys it. Can't wait to be playing AC, COD again, as this system is really old and won' play the newer one.Your mum builds PCs? Kudos to her. Learn from her, its not difficult, and you may enjoy it.
Gigabyte GA-965P-DS3P Rev3.3Xeon E5450@3.2Ghz. T.Tower 1208GB OCZ PC2-6400/Fatal1tyEdition1060 6GBCorsair HX 620WEVO 850 500Gb2 x F3 1Tb Raid01Tb x F13 x Asus VN247H'sNZXT Phantom 820SB ZWhat's your current system?
Brilliant that you and your mum can do that together. She sounds like a goodun.
